100kwh-hunter
- Mar 2, 2019
- 801
I ordered a lot of cells, so far one seller delivered. (16 cells out of 96 cells from ali)
Those 16 are all within 20 to 22 M ohm, all are 3.290V ish, with mu yr1035 4 point meter.
I think they are good?(280 Ah 1C)
I will check for weight tomorrow? it seems to be important?
It was stated those where EVE cells, wrappings are good, no visible damage to the connectors, could be even new?
Anyway before i go charging them, "lock" them up to prevent "bulging"? or is this just a myth?
It is pretty easy for me to put a cast/lock around them to disable any movement. But is it necessary?
Just wooden sheets cut up, Or even a c clamp......nothing fancy.
Tahnks in advance for your answers, with best regards Igor
