ketoneenergies
- Oct 22, 2018
- 10
i made 2 battery packs(16s8p,48ah) with 128(32650,lifepo4,6ah) cells each. The bms i am using can do 50A continuous and 100A peak. when i applied load of 500watts, bms is cutting off the battery. same for both the packs. i am attaching the picture of bms software of each pack. it is seen that on both the packs ,current is drawn from cell no:3,6,9,12,15. bms is cutting off the battery because these cells are going below 2.5v. anyone knows why? is it because of the design? or anything else.
