Option to replace single cell
2weiund2wanzig
Hey,
i saw many styles of configuration of 18650 packs and i like the idea to make bus bars from installation cablecopper and connect the strands to larger busses to the connectors.
What i wonder is how you build packs so that you can replace a single cell (maybe when it gets warm) without resoldering the whole pack.
This is why you bendbusbars to traverse 'between'the cells in the 4 x 5 plastic cell holders. This lets you breakoff the littleplastic tabs... unsolder and push the bad cell thru and then push anew cell into place and re-solder.
Here's a great example from @HBPowerwall - see 2:39 where he actually pops out an old cell...
In addition, I build my packs to have 'empty slots' - so I canadd cells if I need to to boost a pack. I use the 4 x 5 plastic to physically protect the + and - lugs from sticking out past the end of the pack. And if you take this further - you could just cut the wire from a bad cell (leaving it in place)and use a blank spot to add a new cell - but I've not actually done that - I've just added a few cells here and there to help balance out the packs.
2weiund2wanzig
thats a good answer to my question. The empty spaces method and the method shown in the video are what i was looking for.
How i do it. :)
