Doinit said:
yes the outback says an array can be used up to 150v max..
Just fyi, for eveyone else, the above is true for Voc of the panel and not Vmp. He keeps confusing numbers to the point he actually believes in what he makes up and start recommending to other people to follow his thought. Quite absurd.
The Voc is the solar panel at open circuit, which is when the panel isn't loaded and able to produce the maximum voltage. The Vmp is the voltage at max power, which is always lower. For example a solar panel might have a Vmp of 33.4V while the Voc is 40.2V.
So for a controller that can handle 150V max, it means you don't want the maximum voltage the panel can provide.
Using sample panel Vmp 33.4V and Voc 40.2V
3S (3 in series) the Vmp is 33.4V*3=100.2V and Voc is 40.2V * 3 = 120.6V (GOOD)
4S (4 in series) the Vmp is 33.4*4=133.6V and the Voc 40.2V * 4 = 160.8V (BAD TOO HIGH VOLTAGE)
Using sample panel Vmp 26.8 and Voc 34.5V
3S (3 in series) the Vmp is 26.8V*3=80.4V and Voc is 34.5 * 3 = 103.5V (GOOD)
4S (4 in series) the Vmp is 26.8V*4=107.2V and the Voc 34.5V * 4 = 138V (GOOD)
So all that matters is that your Voc does not exceed 150V.
And not the nonsense of the Battery + PV that he's trying to convince you.
