completelycharged said:Summary :
Used == Fuses (fuse the unknown)
New == Nickel (confidence in your "new" product)
Katarn_89 said:This has been discussed a lot. If you look at the build threads the vast majority of people are using fuses because it offers protection that nickel strips doesn't. You could use them on the negative side and fuse the positive side, or use nickel strip as a bus bar with fuses attached to it and the cells.
