To build a pack that is going to perform to expectations with the least amount of trouble requires some forethought.
There are a couple of ways to test cells that will go into the packs.
The (what I call) brute force method which is charge and discharge each cell at 1A to get your mAh results. You will need an OPUS or SKYRC charger tester to be able to do that. Most all the others will charge at 1A but discharge is limited to 500mA.
Anything that gets hot or falls below 80% SOH gets discarded into the recycle bin. The cells that pass get sorted into bins by 100mAh differences and after that an equal amount are taken out of the bins and installed into packs.
It is a rather rudimentary way of doing it but it works so who am I to say any different.
The other (more delicate) way is to take each cell, spend maybe 10 seconds on it and measure the IR and V of the harvested cell to determine if it has any chance of being a good cell. As you learn each of the manufacturer's chemistries and IR readings for each part number you will quickly find good cells, mediocre cells, and bad cells. Here is a sheet that will guide you
https://drive.google.com/open?id=169QnjLDBmFyfOY6RybH0VGBR4bV2NJDT
Yes and all IR measurements are done with a YR1030 or equivalent 4 wire 1kHz tester. See treadhttps://secondlifestorage.com/showthread.php?tid=7742&pid=53191#pid53191 I Personally use a
RC3563 it is the easiest and the best I have found.
I personally made an Excel spreadsheet to analyze each cell. Yes this does take some time but the rewards are worth it.
So that after you have harvested your lot you can then sort by whatever criteria you want to get the best cells for your build.
The sheet with a cell database and all formulas already plugged in can be found here.
https://drive.google.com/open?id=1W8CQa6CIGP6cYvkoTokpdCYUU1V-6Nsj
My personal sheet with lots of extras is here
https://drive.google.com/open?id=1dvcgpoKa-9nBJUTvL9B1vcMSRtIQnzkm
In a nutshell my procedure for testing cells is.
1. Once the cell is liberated out of the pack it is checked for V and IR, anything below 2.5V orabove the recommended IR is set aside.
The cell is given a number (cell is labeled with a sharpie), initial V and IR are recorded in the spreadsheet.
2. Cells are tested with my OPUS, SKYRC, and Foxnovo. I know the Foxnovo only does 500mA discharge. But due to much experimentation and testing I find that if the IR is acceptable, the cell will do just fine whether C/D/C at 1A or 500mA.
3. Results are recorded on the cell via sharpie and again recorded in the spreadsheet which due to the formulas gives a SOH percentage.
4. Once the required number of cells have been collected and the data analyzed the build can begin.
5 I use Nemos Repackr which gives you very well balanced packs with the cell number that you previously marked on the cell with a sharpie.
All that is necessary is to copy and paste the cell number the mAh capacity and the IR into the sheet and give it the criteria for your pack build.
Nemo's Repackr can be found here.
https://drive.google.com/open?id=1l8RNN64bn0wJ9KciT_6XJ75npcFRUl_f
6 Assemble all packs and charge to 4.2 V discharge with iCharger x8 regenerative discharge at 30A note the Ah of the battery and do the next one.
I have 1 more pack to test and so far all have been extremely close in Ah results.
You can view the results here.
https://drive.google.com/open?id=1XuBHDyqCGIjQYYqDJ8WIscmYJ3EAdOAv
or here:
Disregard the 15th pack as I needed to raid it because as I was being overly cautious with cells that were close to the margin of acceptance or not.
So that is my procedure
There is an old saying that goes "There is never enough time to do it right the first time but always enough time to do it over"
I have also added the Excel sheetsas attachments
