Panasonic NCR18500A Cell Specifications
TheBatteries
Brand:Panasonic
Model:NCR18500A
Capacity:1900mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1330mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
380mA Standard
--- mA Maximum
Description:Green Cell Wrapper
White Insulator Ring
18500 Form Factor
Data References:
https://www.antenna1st.com/home/NCR18500.pdf
http://www.hkforceful.com/pdf/4/NCR18500.pdf
http://www.batteryspace.com/prod-specs/10461.pdf
Pictures:
Just stumped on a lenovo pack that had 2x NCR18650Bs and 1x NCR18500A in parallel with some kind of parallel BMS board. They have the exact same color wrappers.
