Panasonic NCR18650D Cell Specifications
TheBatteries
Brand:Panasonic
Model:NCR18650D
Capacity:2900mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1780mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
0mA Standard
--- mA Maximum
Description:Gray Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Wolf said:
mike said:
Wolf said:
That sheet is for CGR18650D, different from NCR18650D.
I know I just corrected that but I saw that they were the same I will get proof if the case.
I saw it had both model numbers on the voltaplex page, but the picture is just a grey cell with no text. Seems odd to me, not sure how reliable that site is? I did a quick search for NCR18650D PDF and found one for NCR18650, but not NCR18650D. I assume the specs are probably the same, but not sure and don't want to assume.
Datasheet
  • NCR18650D S3 SANYO Panasonic.pdf
