Pcm60x charging batteries with wind
Bigfillly
Hi,
I’m thinking of getting a wind turbine and want to know if I can hook it up to the pcm60x to charge my battery bank, is it possible?
Thanks,
Phil.
For wind turbines, you'd need a turbine specific charge controller, because the wind dictates the wattage output, not the controller. It's not like a solar charge controller that can change the voltage/amps on the fly.
No where in the MPP documentation for the PCM60x did I see anything related to wind charge controller.
Bigfillly
Wow, I can always count on you for your wisdom, thanks KORISHAN once again, ill look into getting a wind charger, it was just a thought 😊
Its on the expensive end, but Midnite Classic charge controllers are designed for both PV and Wind and Hydro They have specific wind support / algorithms such as this section from the manual:
A controller that supports wind will have specific "Wind" options.
