completelycharged said:
It may be due to the way you have connected the battery pack and the resulting voltage drop to the pack.
On the screens you show one is saying 27.61V and the other 28.06V at 11A current flow which is a 450mV drop or difference between the reading points. If the two are 28.06V internal to PIP and 27.61V at the pack then this would mean you rleads between the PIP and pack have a resistance of 0.041 Ohms.
At 22A the volt drop between PIP and pack would be 0.9V. This may be creating some of the difference as to when the PIP is switching to CV at a lot lower pack voltage than expected (or reading at the pack) because the voltage internal to the PIP is higher.
hm interesting, that might explain why the charge rate went up so much after i swapped the positive lead from the pack to PIPout from a 14awg 32A rated copper silicone wire to a 57amp rated PV wire. maybe thats why I'm now getting a much closer reading between the 2?
My PIP negative to BMS is currently 2x 16awg 22amprated silicone wires (so 44a combined), I'll probably move them later to something rated 120-150 amps and see if it improves more. the positive will get upgraded to match as well.
Separate thought - how does the PIP screen determine the battery % as it is showing 100% when at 28.06V - indicating it would be at CV...
No idea - a youtube video i saw from another PIP user said the PIP has no shunt and therefor no real way to calculate the %, so the figure should be completely ignored - they shouldnt have even added it to the GUI.
