PIP Inverter Error "error 09" bus soft start failed
ISolar SM 5kw 48vdc = EASUN POWER 5000W Solar Inverter 80A MPPT Off Grid Inverter 48V 220V Hybrid Inverter Pure Sine Wave Inverter 60A Battery Charger
Need your help. The inverter ran without problems batteries at about 57V (14S) and solar was at zero in time because not connected (solar is connected to the PCM60x). Consumption was at about 300Watt / 230V. According to SolarPI everything was ok all day.
But then something must have happened at 16.30 o'clock because the fuses for the batteries and also the solar fuse from the PCM60x flew out.
The inverter was of course without batteries.
I tried to start the inverter normally after switching the fuses back on.
The inverter also starts normally. But reports dan error 09 "bus soft start failed.
And the 230V is not there.
Has anyone with the error 09 already experience and can help me please.
Thanks in advance to all who help me
Greetings Dirk
Please, please, please
Thank you thank you thank you
Greetings Dirk
