TheBatteries
- Oct 8, 2016
- 2,127
Data References:
https://cdn-shop.adafruit.com/produ...0mAh_3.7V_with_PCM_20140728_APPROVED_8.18.pdf
Pictures:
| Brand: | PKCELL |
| Model: | ICR18650-2200mAh |
| Capacity: | 2200mAh Rated |
| Voltage: | 3.70V Nominal |
| Charging: | 4.20V Maximum 1100mA Standard 2200mA Maximum |
| Discharging: | 3.00V Cutoff 440mA Standard 4400mA Maximum |
| Description: | Blue Cell Wrapper Black Insulator Ring 18650 Form Factor |
Data References:
Pictures:
