f72fj752f
- May 29, 2019
- 9
hey im gonna make my very first pack, 6s50p 3000wh mini powerwall and i have all the parts ready to buy but, i cant find an inverter which you can select the cutoff voltage in, one i found was for 21 volts cutoff voltage which means it will cutoff the cells at 3.5 volts but they arent near discharged at 3.5 volts, theyre disharged at 2.9 or 3 volts,
now i could just connect the inverter to the load in the solar charge controller but the solar charge controller only out puts 100 amps or so but id rather connect them to the battery itself so no voltage is changed as i dont think the solar charge controller can supply enough wattage, {2400w} is the max it can output but i need 3000 in my inverter. any help?
