The BMS is nothing more than a smart switch. It can turn on or off based on various measurements. You cant regulate power with a BMS, only turn it off or on.
A bms can do so much more.
especially those of Daly....those are just junkyard dogs....one pinky into the fence and you lose your pinky
So start setting your parameters correct.
For example with the help of a balancer:
You can set your cell limit to max 3v and your system(banks) total at 58v....it will shut off when the first cell hits 3.001v
you can set 48v total system limit and your cell limit to 4.5v, than it will cut off at 48v.
Be wise in this one to get the max out of your bank.
But as always keep your cells happy, with second handed keep max minus 10%, system is next
O yes before i forget there is also a temp limit.
In whatever scenario choose your cell limits first.
Calculate with that one towards your pack/system
Whatever max is reached first that is the one that will trigger the bms to stop charging.
When in ideal, the bms will stop responding and you will need to activate if you want some numbers, please only check when there is some activity by means of dis or charging, when in ideal the bms will shut itself off/.
Daly is a real junkyard dog, it will bite you to protect your system!
With best regards Igor
