Processed Submissions and Updates
Status
Not open for further replies.
good unknown cell all over 2000mah most 2200-2350mah
Google search turned up nothing on markings
markings on cell
+ICR18650A-2000mah-
3.7V FS 15K11
Note: Can you please take some pictures that are more in-focus? Thanks.
Mark Lex
Samsung ICR18650-22B photos
No other info..
LGES318650 photos
Undocumented 18650 cell:
LGEP218650
purple wrapper, white ring
photos for Samsung ICR18650-22FU
Green wrapper
White ring
Note: Added, thank you!
Sona battery pack LS LR1865LA cells from alarmhookup (ebay)
What I found on the net they are Tianjin Lishen 18650 electric tools lithium LR1865LA10C cells
white/light grey ring Green wrapper Gold band on negative end.
The cells are green the gold band on the one i took the photo of is mylar . Just opened another pack up and no mylar all a pretty green.
new photos hopefully better
the batteries kept rolling so I placed a piece of board in front of them for the photos
better pics at last
The last pack I processed hada few cells with a letter- six digit number C,D, F are the letters I have seen so far.
Lishen LS LR1865LA li-ion 2000mAh 10C 20A
??????????? ????????: 2000mAh
??????: LS LR1865LA
??????????? ??????????: 3.6V / 4.2V
???????? ??????????: 4,2 0,05 ?
????????? ??????????: 2,75 0,05 ?
??????????? ??? ???????: 1C
???????????? ??? ?????? 1? (T?10 ?)
???????????? ??? ???????: 10C 20A (t?0 ?)
?????????????: ? 15 ???
????????????? ???????????: ??? ??????? 0 ~ 45 ?, ??? ????????: -20 ~ 60 ?
??????: 65,1 ? 18,4 ??
???: 46 ??
haven't found datasheet yet. but it is out there.
Note: Need pictures before we can create a database entry...
wimpie007
Lishen (LS)LR1865SE
Gray White (same as 1865SF)
Lithium ion (Cylindrical)
Nominal Capacity: 2200mAh
only info I could find: https://fccid.io/UL/TIANJIN-LISHEN-BATTERY-JOINT-STOCK-CO
LG AAS31865
Is already in the DB but mine appear to have a lighter shade of blue wrapper.
Note: Added as a variant to existing entry, thanks!
LG EP21865
Purple White
Nominal Capacity: 2600mAh
only info I could find: https://www.tokopedia.com/kisahkomputerku/baterai-18650-lg-ep2
Note: Added pics and capacity to existing entry.
Sanyo/Panasonic UR18650A
Is already in the DB but mine have a purple ring, perhaps like the one noted in the DB without a model number?
Markings SANYO L
UR18650A N35A
Datasheet as attachment
  • SANYO UR18650A.pdf
Wattsup
Panasonic
UR18650NSX
Let me know if these photos are notok Mike
LGDBHE41865
Magallanes
This cell was pulled from a Dell batt.
The number on it is LI8M3C9. Did a search but found null. Maybe you guys have better luck.
Note: Unable to identify model number of cell.
John877
I think I have found a new variation of the Sony SE US18650GR. They dont match any of the existing pictures in the database.
Under the SE US18650GR it has T 7C114PI12C. I dont know if that is anything or what it means if it is anything. I dont know the mAh either as it doesnt say. The outer casing of the battery pack said 11.1V 4800mAh though and had 6 cells in it.
I also found some others that arent in the database at all.
Info is:
KMASHI Battery Pack (15000mah) (8 Cells)
KMASHI S106 18650KAHL
AEJDBJ 3.7V
Ihopethis is the right way to get the pictures and information I have on the cells to you. If not, sorry up front.
I'm uploading 5 new cells. 2 are LiFePO4 18650, 1 is a 26700 cell, and 2 others are 18650 probably high drain cells (salvagedfrom powertool packs), but I can't find data on them.
--------- info on cells such as I have -----------
us18650FT --> LiFePO4 --> https://produktinfo.conrad.com/date...-da-01-en-SONY_18650_LIFEPO4_AKKU_1100MAH.pdf
A123 apr18650M1A ---> LiFePO4 --> http://www.batteryspace.com/prod-specs/6612.pdf
LS IMR26700 --> This may actually be a Lishen battery, but only spec sheet I can find is for a Molicell version that looks identical in google photos --> https://evmc2.files.wordpress.com/2013/12/imr26700.pdf
High Star ISR18650 --> No data sheet found (salvaged from a power tool, so most likely high drain)
SF US18650V --> No data sheet found (salvaged from a power tool, so most likely high drain)
photos (i've tried to give the files useful names)
rebelrider.mike
I came across a couple cells I don't see in the database. First is marked +FP. I found 6 of these in really good shape. Tested well too.
The second looks like an LG, but there is no brand name written. Also, the code doesn't match up with anything. I only have 3 of these, and physically they are in kind of rough shape, but they also tested well. Here's the best one of the three:
Amigaman
Sam Whitehead
First post :cool: !
Sanyo UR18650FB. Marked with embossing to red sheath.
I have about 500 of these to test (obtained for free for my own use). All removed from single cell packs. Tested on B6 clone charger and opus at around 2200-2300mAh.
I haven't found the official datasheet butI've found bits of info on eBay and Alibabaindicating 2400mAh capacity, 1C charge/discharge (2C peak).
Status
