Processed Submissions and Updates
Status
Not open for further replies.
chiphead
Datasheet:https://na.industrial.panasonic.com/sites/default/pidsa/files/panasonic-ncr18650bd-datasheet.pdf
Brand: Panasonic
Model: NCR 18650BD
Capacity: 3100 mAh
Description: Grey Wrapper, White Ring, 3 tab positive
18650 Form Factor
Note: Added, thank you!
OhmGrown
So just rescued6 of these from a Rayovac laptop battery. Model number shows to be 240 and I only saw the 220 version in the database (which has a different color insulation ring). Haven't done any discharge tests on em yet but the pack read 10.8V with 5000mAh and 54Wh. So guessing they're about 2500mAh if that's accurate (prob 2400 based on the model number). Also tried checking online for a data sheet but no luck. I'm not the best at finding those though honestly.
Brand: YLE (YikLik?)
Model: ICR18650A240
Cell Color: Orange
Insulator Ring Color: White
OhmGrown
Not sure if the database has a typo or if this is actually a different type of LG cell. Database shows DB11865. The ones I've found are same teal color but have an extra B in there.
Brand: LG
Model: DBB11865
Color: Teal
Ring: White
Couldn't find this Sony cell in the DB. Its a Sony Energytec I suppose, not sure if that's significant or not. Shows a similar model number to others from Sony but different model number and wrapper.
Brand: Sony Energytec
Model: US17670GR
Color: Green
Ring: White?
Note: Pictures added to existing entry. Couldn't locate cell specs though. Thanks!
OhmGrown
LG cell out of an HP pack of 8 cellswith a similar model number as other LGs inthe DB. Saw some similar model numbers but with totally different colors.
From what I've found online from some flashlight seller, these are only 2200mah.
Brand: LG
Model: LGES218650
Color: Peach
Ring: White
mAh: 2200?
xxlawman87xx
Brand:
Sanyo
Model:
INR18650A245
Capacity:
2450mAh Rated
Voltage:
3.60V Nominal
Charging:
4.20V Maximum
490mA Standard
1715mA Maximum
Discharging:
3.00V Cutoff
490mA Standard
4900mA Maximum
Description:
Red Cell Wrapper
White Insulator Ring
18650 Form Factor
Note: Added, thank you! Also, not a Sanyo just FYI.
OhmGrown
I keep finding LG cells with model numbers that are very similar to ones in the database but with like one digit or letter off.
I think this one (DBD1) is actually the same ratings as the ABD1 based on the specs on the pack (11.1V &97Wh (3S3P))
Brand: LG
Model: DBD11865
Color: Pink
Ring: White
OhmGrown
So this is a head scratcher but I just opened a Dell pack and was greeted with these paper covered cells with absolutely no markings whatsoever. Even unwrapped the paper thinking maybe they just covered the markings or heat shrink up but no dice. Just the metal outer housing underneath.
I'm guessing they're cheap Chinese cells (which is weird considering they came from a very well know laptop brand). And I'm not sure if these will actually help anyone or even belong in the database cause of it. But they apparently are 1800mAh based on the pack specs. No idea on brand or model though.
Note: Thanks, but we need to be able to identify brand and model number so we can create a listing.
wimpie007
I see the Sanyo UR18650EA is not present in the DB yet.
Voltage, charge max. 4.20
Voltage, nominal 3.60
Capacity, max. 2350.00 mAh
Other info: Source
Chablism
Can not find any infoon this one online
Unknown; LB-CY/A3 2000mAh LIBO HQE09
Note: We need a picture of the positive end straight down from the top so we can create an entry. Please see this post for an example.
collinkoolen999
Brand: LG
Model: LGDBMG11865
Capacity: 2900mAh Rated
1650mA Standard
10000 mA Maximum
Description: Light purple
OhmGrown
Found these in a supposedly 14.8V and 2600mAh laptop pack. But pretty sure that was all bullshit considering the cells have 2000mAh written on them. But they seem to be similar to the other FST models in the database so far, just with different capacity and slightly different color.
Brand: FST
Model: 18650-2200mah (?)
Cell Color: Blue
Insulator Ring: White
Capacity: 2200mAh
Nominal V: 3.6V
Niemma
Database have grey,found another wrap color.
Brand -Moli Energy
Model -[size=small]ICR-18650G
Wrap color -[size=small]Turquoise
Ring color - Black
[/size][/size]
[/size][/size]
Note: Added as a variant of the current entry. Thanks!
ChrisD5710
LGEBMG11865 (e-bike pack)
2850 mAh
Light purple, white ring
standard voltage: 3. 6v discharge cut-off voltage: 2. 5v discharge current: max. 10a
ChrisD
Note: Please take some pictures. We can't use pictures from the internet.
IronSky
LGEBMJ11865
from E-Bike Bosch POWERPACK 500 FRAME
3.7V 3500mAh LG 18650MJ1 battery supply by UNICELL in Singapore
UNICELL a Leading battery product supplier in Singapore Malaysia Indonesia Philippines Brunei and Thailand since 1986, we carry more the 66,000 model
Order code: LG18650MJ1 (LG 18650-MJ1 battery)
3.7V 3500mAh 10A LG 18650MJ1 Li-ion battery
Specifications
Voltage: 3.7V
Capacity: 3.5Ah / 3500mAh
Size: Dia. 18mm x Height 65mm
Cut off Voltage: 2.75V
Full charge Voltage: 4.2V
Max. Discharge Current: 10A / 10000mA
Battery Info
Status
