I have found a new LG cell that I can't seem to find any reliable information on. I don't think it to be new year wise as I did find them mentioned on a different forum from 2014.
The limited information I have found leads me to believe they are a 2800 mAh cell. My testing on an Opus is getting around 2500 mAh at 1 Amp dischargefor the first few I've tested.
I have another FST variant 6k60114. Blue overwrap, white insulator, removed from 9 cell laptop battery. They are currently in 'batteries' of 3 cells, so I have not tested an individual for capacity.
I have found this cells too, red wrap, red ring.
I got them (9 cells, 3x3 evidently) from an old Toshiba notebook. Regret I have not kept the outer label of the battery pack.
They too have the "F" engraved at the bottom. Also, there are very light stamping on the cells: HBOFJH3 (the same on all cells) and then a six-digit coded lot/date/... (e.g. 066089, 066121, 054468,...).
The Green one are from a chinesse unkown brand FP 18650, but looks it has the rated capacity, tested with my modded opus.
these was also harvested from some counterfeit batteries that also has a fake rated capacity in their label. Also the text looks self explanatory, it shows the production date and the capacity.
I snagged these from a RAV Power replacement laptop battery. They appear to be 2200mah, but I don't see it on the datasheet. They are light blue, white tipped.
Note: Can you please clean off the glue and take some new pictures? We need two pictures, like the examples here, to create a new entry. Thanks!
Orange Wrapper purple ring.
from a a Dell laptop battery - 4 cells per battery.
Very faint markings on the cell itself (couldnt get the camera to pick it up!)
markings are SD8T4A9 on all the cells, and BSD8H3 printed onto the -ve base.
Note that the +ve end also seems to have a manufactured hole dead center!
Note: Need better pictures that aren't glowing please...
lgabc11865 J067C086A3 Any information on MAH would be appreciated.
Testing all over the place from 400 mah up to 2000 mah. From Dell Latitude laptop batteries.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
