Processed Submissions and Updates
Status
Not open for further replies.
Sanyo UR18650FM 2.6A
from a cell pack for HP
may be is ok for someone
Note: Added, thank you!
I have found a new LG cell that I can't seem to find any reliable information on. I don't think it to be new year wise as I did find them mentioned on a different forum from 2014.
The limited information I have found leads me to believe they are a 2800 mAh cell. My testing on an Opus is getting around 2500 mAh at 1 Amp dischargefor the first few I've tested.
LGDC118650
I have another FST variant 6k60114. Blue overwrap, white insulator, removed from 9 cell laptop battery. They are currently in 'batteries' of 3 cells, so I have not tested an individual for capacity.
Note: We need two pictures, like the examples here, to create a new entry. Thanks!
I have found this cells too, red wrap, red ring.
I got them (9 cells, 3x3 evidently) from an old Toshiba notebook. Regret I have not kept the outer label of the battery pack.
They too have the "F" engraved at the bottom. Also, there are very light stamping on the cells: HBOFJH3 (the same on all cells) and then a six-digit coded lot/date/... (e.g. 066089, 066121, 054468,...).
Note: Unable to identify model number of cell
I thought in upload some photos from my cells i have that i didnt find in the database.
The UR16650ZT i get it in some lenovo Laptop battery, which are the orange one.
Here is the datasheet:
https://na.industrial.panasonic.com/sites/default/pidsa/files/ur16650zt.pdf
The Green one are from a chinesse unkown brand FP 18650, but looks it has the rated capacity, tested with my modded opus.
these was also harvested from some counterfeit batteries that also has a fake rated capacity in their label. Also the text looks self explanatory, it shows the production date and the capacity.
Note: Already have both in the database
LGES218650
6 cells from a genuine HP battery module HSTNN-LB42
still charging but seem to have similar characteristics as the other LG S2's in the database
Note: Added as variation to existing record. Thanks!
Sanyo
UR18650A
Blue insert
Have 5 of this cell and will test tomorrow
Samsung 30A says there was no photos
Note: Added the Samsung photos, thanks! I'm not sure that's a UR18650A cell?
Panasonic NCR18650PF
(Successor of theNCR18650PD)
  • Lite green heat shrink tubing
  • white insulation ring
  • black markings and warning text
  • positive and negative side marked as well
EDIT:
I just realized that somebody was a bit quicker than me :(
Note: Please take some of your own pictures. We can't add pictures that were downloaded from somewhere else on the internet.
  • Panasonic NCR-18650PF.pdf
I snagged these from a RAV Power replacement laptop battery. They appear to be 2200mah, but I don't see it on the datasheet. They are light blue, white tipped.
Note: Can you please clean off the glue and take some new pictures? We need two pictures, like the examples here, to create a new entry. Thanks!
Looks like a new submission, can't find it in the existing DB:
Brand: Hitachi Maxell
Model: INR18650PB1
Capacity: 1450mAh Rated
Voltage: 3.7V Nominal
Charging:
4.20V Maximum
--- mA Standard
2000 mA Maximum
Discharging:
2.5V Cutoff
--- mA Standard
15000 mA Maximum
Grey Cell Wrapper
Black Insulator Ring
18650 Form Factor
Cell specifications can be found on page 8 of the attached PDF.
  • INR18650PB1.pdf
Found this cell today and here is some info I found on the original pack
UNI-SUN(TM) Li-ion, 11.10V, 4800mA 6-Cell Laptop Battery f??r Acer TravelMate
Teal Cell from generic no name laptop battery:
FST seems to be the brand.
Orange Wrapper purple ring.
from a a Dell laptop battery - 4 cells per battery.
Very faint markings on the cell itself (couldnt get the camera to pick it up!)
markings are SD8T4A9 on all the cells, and BSD8H3 printed onto the -ve base.
Note that the +ve end also seems to have a manufactured hole dead center!
Note: Need better pictures that aren't glowing please...
lgabc11865 J067C086A3 Any information on MAH would be appreciated.
Testing all over the place from 400 mah up to 2000 mah. From Dell Latitude laptop batteries.
Dyson INR-20700A 0842GB2107
Just pulled out 6 of these from Dyson battery pack. They all show 4.7v. I think my multimeter is busted.
Photos attached
Note: Added, thank you! Interesting note, these are actually rewrapped Moli Energy cells.
Brand: Moli Energy
Model: IMR-18650E
Capacity:?
Description: White-Grey Cell Wrapper
18650 Form Factor
Status
