Processed Submissions and Updates
Status
Not open for further replies.
BigWillTX said:
From a dell laptop battery type W1193
Rated capacity Min. 2700mAh
Capacity Min. 2750mAh
Typ. 2900mAh
Nominal voltage 3.6V
Charging CC-CV, Std. 1375mA, 4.20V, 4.0 hrs
Weight (max.) 48.0 g
Temperature
Charge*: 0 to +45C
Discharge:
-20 to +60C
Storage:
-20 to +50C
Note: Added, thank you!
LGDBMH11865 Light Blue, White ring (from e-bike).
Battery Name: LG
Battery Type: 18650 MH1
Battery Specifications: about 18 * 65 (MM)
Battery Voltage: 3.6V
Battery capacity: 3200mAh
Battery Weight: about 44g
ChrisD
Note: Already had info, but thank you!
Sony US18650VC7
Nominal cap: 3500 mAhRated 3400 mAh
Green, black ring
Data file found but upload not accepted .pdf.
ChrisD
Note: Please provide link to datasheet
Brand:LG
Model:LGGBF1L1865
Capacity:3350mAh Rated
Voltage:3.7V Nominal
--V Maximum
Charging:--A Standard
--A Maximum
Discharging:--V Cutoff
--mA Standard
--mA Maximum
Description:18650 Form Factor
Note: We need pictures to create a database entry...
Samsung INR18650-33G
The cell is quite sensitive on the negative pole. If you pull to hard to remove the nickel strips, a type of cap pops of. Could this be something like explosion protection?
Found a cell not in the database:
SONY-FUKUSHIMA 17670 G6
I'll try to get better pictures of them.
Moreover, the Highstar ISR18650-1300 already in the database has changed the style to a different one like this:
Note: We need better pictures of a cell that is not physically damaged. Please and thank you.
LG18650M26 is the LG medium power cell with capacity of 2600mAh and 10A continue discharge current, a very popular economic cell used in power tools, energy storage, home appliance, and medical device
3.6V
10.0A
Note: Please take your own pictures. We cannot use pictures from the internet.!
I have these cells too, but from a different factory LGGBF1L1865
LGDBMH11865
Model
[size=x-small]LG MH1
Nominal capacity
3200mAh
Nominal voltage
3.7V
Charge voltage
4.2V
Discharge cut-off voltage
2.75V
Charger method
CC-CV
Weight
451.5g
Charging time
Standard charge: 2.5hours
Rated charge:2.0hours
Temperature:
Charge: 0 to 40C
Discharge: -20 to 60C
storage: 1 year:-20 to 25C
3 months:-20 to 45C
1 month:-20 to 60C
[/size]
Adding info below, because the board requires me to make at least one post before adding links...
Seen some discussion on these Panasonic cells, but none in this thread or in the database... So here goes!
Data Sheet (PDF)
Note: Already got it, thanks!
GP Batteries GP1865L180
Nominal Voltage: 3.7 V
Capacity: Typical: 1800 mAh
Minimum: 1750 mAh
Discharge: Standard: 360 mA
Max: 1800 mA
Cutoff 2.8 V
Charge: 1080 mA
4.2 V
Note: Created database entry. If you have time, please upload a few pictures in a standard aspect ratio (non-cropped) that we can use. Thanks!
  • 1865L180.pdf
Here's some pictures of the purple variant, which has part number LGEBE11865:
Sanyo UR1665ZTA
Typical Capacity: 2500 mAh, Nominal Capacity: 2380 mAh
Charging Voltage: 4.35 V
Charging Current: 1190 mA
Cutoff Voltage: 2.5 V
Data Sheet
Update: GP Batteries GP1865L180 New Pictures
Note: Updated, thank you!
  • Sanyo-UR16650ZTA.pdf
Status
