Processed Submissions and Updates
Status
Not open for further replies.
LGDAME11865
Brand: LG
Model name(s): LGDAME11865,ICR18650ME1
Weight 43.60 g
Diameter, max. 18.30 mm
Height, max. 65.00 mm
Voltage, charge max. 4.35 V
Voltage, nominal 3.75 V
Capacity, max. 2100 mAh
Constant charge current, max. 2.10 A
Charge constant standard 1 A
Max. continuous discharge current 4.20 A
Peak discharge theoretic, 4 sec 7.35 A
C-rate (charge, max.) 1 C
C-rate (discharge, max.) 2 C
Watts (charge, max.) 7.875 W
Watts (discharge, max.) 15.75 W
Energy, max. 7.88 Wh
Density volumetric theoretic 461 Wh/L
Density gravimetric theoretic 181.00 Wh/kg
E-rate (charge, max.) 1 E
E-rate (discharge, max.) 2 E
NMC
Cathode LiNiMnCoO2
Anode carbon
Temp charge, min 0.00 C
Temp charge, max 45.00 C
Temp discharge, min -20.00 C
Temp discharge, max 60.00 C
Internal impedance 6 m?
Note: Added, thank you!
Sanyo R1112 from YamahaEC-03 2011
Note: We need higher quality pictures please...
Found some LG cells that don't appear in the database. LGABD21865. Found in two Dell 65 Wh laptop packs (P/N 04KFGD). All tested right around 3000 mAh and around 50 milliohms.
I guess this are some Sanyo cells. No print or stamp at the isolation.
Just printed dirctly on the cell:
"IQFJT
090402"
red wrapping and red isoilation ring.
Note: We need a model number to create a listing. They look like they might be UR18650FJ but unable to confirm with certainty.
One more that's not in the database, Lishen (LS) LR1865BE. Datasheet here:http://www.batteryonestop.com/baotongusa/products/datasheets/li-ion/LR1865BE-1400.pdfPulled from a Rigid 18V 26WH tool pack.
[size=small]Brand:
Lishen (LS)
Model:
LR18650BE
Capacity:
1400mAh Rated
Voltage:
3.70V Nominal
Charging:
4.20V Maximum
1400mA Standard
4200mA Maximum
Discharging:
2.00V Cutoff
10000mA Standard
25000mA Maximum
Description:
Light Purple Cell Wrapper
White Insulator Ring
18650 Form Factor[/size]
Status
