zoepionierin
- Aug 23, 2019
- 4
LGDAME11865
Brand: LG
Model name(s): LGDAME11865,ICR18650ME1
Weight 43.60 g
Diameter, max. 18.30 mm
Height, max. 65.00 mm
Voltage, charge max. 4.35 V
Voltage, nominal 3.75 V
Capacity, max. 2100 mAh
Constant charge current, max. 2.10 A
Charge constant standard 1 A
Max. continuous discharge current 4.20 A
Peak discharge theoretic, 4 sec 7.35 A
C-rate (charge, max.) 1 C
C-rate (discharge, max.) 2 C
Watts (charge, max.) 7.875 W
Watts (discharge, max.) 15.75 W
Energy, max. 7.88 Wh
Density volumetric theoretic 461 Wh/L
Density gravimetric theoretic 181.00 Wh/kg
E-rate (charge, max.) 1 E
E-rate (discharge, max.) 2 E
NMC
Cathode LiNiMnCoO2
Anode carbon
Temp charge, min 0.00 C
Temp charge, max 45.00 C
Temp discharge, min -20.00 C
Temp discharge, max 60.00 C
Internal impedance 6 m?
Note: Added, thank you!
Brand: LG
Weight 43.60 g
NMC
Cathode LiNiMnCoO2
Anode carbon
