As someone working for a company that is using 4s3p battery packs with the Sanyo UR18650A in theier product, i can tell you we face to issue of overheating cells too. After investigating the issue for entire year now, i like to share me insight with you.
As we know, the cell voltage starts to drop after the cell hits 4050 mV to 4200 mV and it releases a condierable amount of heat.
Despite the BMS cuts off the charge current once the temperature hits 60C, the temperature keeps rising for several minutes. The reaction that was triggered by charging the defective cell is self-sustaining even if the charging is supended. The highest temperature I recorded is 93C.
It's also clearly visible, that not all cells reacs this way:
First we let some defective cells analyze by a specialized company. This is the original summary:
"The answer is that there are several micro-shorts appears from the negative electrodes through the separator to the positive electrodes. It is clear that negative electrode, separator and positive electrode are glued together. The reason behind may be due to long time charging and discharging at high temperature. However, it is very hard to obtained any evidence. In the same pack, several cells has the similar micro-shorts appearance when they opened the cells and checked under the microscope."
Yes, internal short circuits where kind of expected as this is the only way the cell can produce any heat on it's own. Also the self discharge rate of defective cells is about 3 times higher than the one of new cells.
So, the UR18650A just doesn't like high temperatures. If you look at old datasheets, the cell was rated for a charge temperature up to 45C. In the newer once only 40C. Panasonic knew for several years, the cell gets damaged when it is charged at high temperatures (but they didn't tell us, so we run into the issue and had to investigate it by ourself).
As a test, I took several brand new battery packs and charged them to 4.2V/Cell and 0.6C at an ambient temperature of 50C to 55C with one or two cycles per day. And sure enought, after 280 days the self-discharge rate of some cells rised so high, the BMS struggled to keep the battery pack balanced despite active balancing build in.After just 334 days and 440 cycles the fist cell showed the exothermic effect.
We also run a second set of battery packs at the same ambient conditions, but only charge them to 4.1V/cell, and they are still fine even without cell imbalance.
But after seeing a lot of reports from failed battery packs, I think not charging at high temperatures is the problem, but keeping the cell constantly at 4.2V at high temperatures (50C to 55C). The batteries typically fail after 18 to 36 month and as we use the batteries only as back-up, so they have a low number of cycels, usually around 50. I even saw a battery pack failing after just 15 cycles (and 2 years age)!
Oh, and the capacity is still fine, even 80% and more for some defective packs.
Time for a summary:
- Don't keep the UR18650A charged to 4.2V at high temperatures.
- The cells develop a internal short circuits. This effect is permanent and can not be reversed with conditioning cycles. Treat cells that come from a high temperature environment with extrem care.
- You can avoid the triggering of the exothermic effect of defective cells by reducing the charge voltage, charge current and ambient temperature. But the parameters are different for every cell and there is no "safe" area.
- Despite a saw a lot of defective batteries, non of them reached the termal runaway (charge current always cut off at 60C, pretty sure if you keep charging it will eventually catch fire). But don't trust your life on my experience. The cells are very dangerous and we immediately take the failed battery packs out of service when we detect an anomaly.
I hope this information helps you.
What I'm interested in, have you ever had a cell that hit the thermal runaway?
Geek said:
Do these self discharge if left to sit? I find that most of my heaters, while they won't charge above 4.1v they don't tend to self discharge below 4.05v. As stated before - they do make excellent torch batteries.
The self discharge rate of defective cells is about 3 to 6 times higher compared to brand new cells.
Wolf said:
Chiming in here with some research data.
Great, thank you.
