I'm currently working on about 1.2tons of laptop batteries. We So far we are seeing a majority of Red Sanyo's coming out of Lenovo/IBM 9 Cell packs. Although funny enough randomly the purplePanasonic 18650GR's come out of a slightly different model 9 cell but still Lenovo...
I'm using the LiitoKala Pro, I have 19 of them and 4 Opus chargers. After cracking packs, stripping electronics I then do a voltage test. I was previously accepting 1.5V or better to be put in line to be charged, but I was having like 50% heater/failure rate on the chargers. I'm also considering the wear and tear on the chargers, my fingers and most importantly time.
So I've adjusted my cut-off to 2.5V, which is giving much better results. I still have some heaters, but I went from like 40 odd per battery change ( 92 cells per change total) to today only 8 HH.
Basically your "normal batteries" should go through a LiitoKaala in about 6 hours depending on how charged it was before it started. The Liito seems to measure the mAh it takes to fully charge the battery(on quick test mode), not a discharge like the Opus does.
So the majority of my heaters are then "waitlisted"...
Next problem is I'm running out of storage. @ 1.2Tons of batteries, lets say about 3 packs per 1kg, Thats 3600 packs @ 6~9cells each:I have 20 000 ~28000 cells I need to test with only a 92 cell charging capacity which I can cycle maybe twice sometimes thrice per day.
Anyway so hence my sorting methodology.
Also once capacity tested and labeled, I then box up and let lie for 30 days. I then measure Voltage again and see who drops more than .2V. Anyone who does is waitlisted again.
