Resources and info on fixing Milwaukee m18 batteries
Tivy
Hi Y'all,
I'm looking for some resources on how to replace cells on m18 tool batteries. I haven't been able to find any on this site, or elsewhere. Lots of resources on identifying bad cells, but I'd like to take it a step further.
Thanks!
It's not clear to me what you are looking for. Generally, if you open one of these you'll find a bunch of cells that have been spot welded to each other, probably with some kind of frame. To fix it, you'd need to break those welds, test cycle each cell and replace those that are bad, or better, replace them all as that will produce a more balanced pack.
You'd need to see what cells they are using and replace with cells that can match the performance (particularly in terms of discharge rate). It's also not particularly easy to solder in replacement cells, and the heat from soldering is going to impact the cell performance (from minor to horrible). It is better to spot-weld again, but that's a price impediment to be sure.
If you have no experience with this, you need to do some learning. Li-Ion cells are quite dangerous when mishandled. A shorted cell or pack can lead to runaway thermal issues that produce a fire that is very, very difficult to stop.
Ive found its EXTREMELY difficult to repair an m18. They have a spot on the pcb that must remain powered, and if you break that bus to get at the cells its a wrap for that bms pcb. So if you do a lil more digging there is a way to keep it powered, but you are a bad man if you can do it. It only cost me one pack, I think I could do it if you wanna donate. This time Ill solder a lead to the test point after a proper tinning
khauser said:
[...] It's also not particularly easy to solder in replacement cells, and the heat from soldering is going to impact the cell performance (from minor to horrible). It is better to spot-weld again, but that's a price impediment to be sure [...]
Worth strongemphasis: not only may soldering to cellsdegrade their performance, but it may also make themmuch more dangerous. See the many warningshere to never solder cells(from all the major manufacturers).
Kcchris816 said:
Ive found its EXTREMELY difficult to repair an m18. They have a spot on the pcb that must remain powered, and if you break that bus to get at the cells its a wrap for that bms pcb. So if you do a lil more digging there is a way to keep it powered [...]
Laptop packs are the same way: you have to be very careful swapping the cells. If the BMS detects any anomalous events then it may permanently disable the pack(e.g. blow a hard fuse). So it's a bit like open heart surgery: you need to keep the BMS alive during the cell swap and ensure it sees nothing weird (e.g huge voltage imbalances). For laptops it's even worse: once the BMS loses power you cannot reboot it without a proprietary password and software (except for very old BMS boards). But cell swappingcan be done successfullyas long as you are aware of these matters and are very careful. But you may end up with a very confused fuel gauge if you use different cells.
Thanks! could a dc power source alligator clip onto the bus?
Like the one I've linked to below? Or spot weld a jumper onto the bus to clip onto?
I was hoping I could find a picture or video of exactly where the positive and negative would need to attach to keep the pcn powered.
Thanks everyone!
https://www.amazon.com/Yescom-Preci...ocphy=9032583&hvtargid=pla-348683490679&psc=1
I agree that it is difficult to repair an M18. And it's because the tamper protection they put on.
Basically, if you disconnect the cells and break the circuit, a chip will self-erase and your battery is dead no matter what cells you put in there. You will have proper voltage but it will just not start. So you should keep it powered while you make the replacement and that may be very difficult unless you have a very good adjustable voltage source.
You will have to set the source at the current overall voltage level, increase to the new level and make the replacement, then disconnect the external source.
See this video:
And the 1st comment.
I have been able to repair a m18 battery without keeping the bms board powered. I have a 9.0ah battery that wasn't charging, and i had removed the bms board to look at it closer before reading anything about keeping power on it. I found a burnt smd fuse right behind the charge pin which was causing the issue. It was a green unmarked component. Soldered the board back in, bridged the fuse with solder and the battery works now. The indicator lights on the battery started working again once it was placed back on the charger.
i think R&D battery as well as Batteries and Bulbs have rebuild services where you send in the old battery and they replace the individual cells. you can even specify what brand replacement cells are used.
Well I just found this video the guy does not supply voltage to BMS while he removes the batteries and he manages to put it back together and it all works not sure what to believe anymore its 5.0 XC battery too but I attempted this repair and now I only get the tool light to come on and nothing else works not charging, I have proper voltages on all cells and total charge is 20.95 so very unfortunate
