Ok, it is time to release the next set of results. Finally seeing some degradation! Here's the chart:
And a little closer look:
You can see a definite trend. Just going to repeat a few things if you don't want to read from the beginning. Since I am rotating cells every 25 cycles, and the right two slots get warmer than the left two slots, when a cell is on the right side, it benefits from heat adding capacity, and when it goes from slot 4 to slot 1, the capacity takes a hit. Also, the missing data for the THLD cell in Cycle 129 is from the slot being sticky and going null on the recharge. I didn't get a reading, but when I took the cell out and put it back in, it was at 3.29V, so I know it had gone through a full cycle. Also, because I am rotating every 25 cycles, I wait until 5 cycles into the next rotation to compare to the first 5 cycles, so that there is no slot selection effect.
With that being said, here is the degradation observed over 205 cycles. The first row is the average of Cycles 1-5 and the second row is the average of Cycles 201-205 for each cell. The third row shows the percentage of degradation of eachcell.
Please keep in mind that the LG cell did not start out this test as a new cell, and already had a number of cycles or cycle equivalents on it before the test got started. The other cells are 8 year old cells that were never used. And as most of usknow, degradation is not linear, it accelerates.
Anyway, I'm continuing this test. I just finished Cycle 213. I would have posted this earlier, but I didn't really have a chance.
