Samsung ICR18650-22E Cell Specifications
TheBatteries
Brand:Samsung
Model:ICR18650-22E
Capacity:2200mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1100mA Standard
4400mA Maximum
Discharging:2.75V Cutoff
440mA Standard
4400mA Maximum
Description:Teal Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Samsung ICR18650-22E.pdf
Pictures:
Though a 2C charge rate is mentioned later in the datasheet, the max charge rate is technically 2200mA.
