Samsung ICR18650-22FU Cell Specifications
TheBatteries
Brand:Samsung
Model:ICR18650-22FU
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
2200mA Standard
4400mA Maximum
Description:Green Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Found these details on Alibaba.com
SAMSUNG ICR18650-22FU
Nominal Capacity - 2200mAh(0.2C,2.75V discharge)
Minimum Capacity - 2050mAh(1.0C discharge)
Charging Voltage - 4.2V0.5V
Nominal Voltage - 3.6V
Charging Current
Standard charge - 1100mA
Rapid charge - 2200mA
Charging Time
Standard charge:3hours
Rapid charge:2.5hours
Max.Charge Current - 2200mA
Max.Discharge Current - Continue discharge at 6600mA(3C)
Discharge Cut-off Voltage - 2.75V
Weight - 44.5g max
Found this datasheet, seem pretty accurate according to my test.
  • Samsung-ICR_18650-22F-datasheet.pdf
How can I tell the polarity of the battery? there is no sign or label and both ends are flat.
In the image above it's the second photo of the cell, also if you look on the side there is like a little notch, that's the positive side
