Samsung ICR18650-30A Cell Specifications
TheBatteries
Brand:Samsung
Model:ICR18650-30A
Capacity:3000mAh Rated
Voltage:3.70V Nominal
Charging:4.30V Maximum
1500mA Standard
6000mA Maximum
Discharging:2.75V Cutoff
440mA Standard
6000mA Maximum
Description:Purple (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Samsung ICR18650-30A.pdf
Pictures:
OK, this is getting complicated:
I always test my cells at 1000mA discharge current, going from a 4.2V full charge down to 3.0V on testers with separate voltage sensing leads. I use only cells that are over 75% of their nominal capacity in my builds. However, I am now seeing more and more cells that have a full-charge voltage of 4.35V and a cut-off voltage of 2.75V, like the cell from Samsung in question.
I have a munch of iMax X6 hobby chargers and a couple of Liitokala Lii-500 clever ones as well. Anyone knows of a way I could charge a cell up to 4.35V with these devices? I can easily then test a couple of cells down to 2.75V at 500mA and adjust the rest of the cells' SOH accordingly.
I would expect an increase of around 5-6% at SOH if I test according to specs.
Here's the most recent spec sheet I could find (the one linked here doesn't work):
http://gamma.spb.ru/media/pdf/liion-lipolymer-lifepo4-akkumulyatory/ICR18650-30A.pdf
(shouldn't the spec sheets be saved somewhere on this server, btw?)
According to lygte-info(slightly different cell), the per-specs testing should boost capacity around 16%, compared to my typical testing!
This is what I put under a 'cheat cell' spec. Same as 28As, 28Bs.
I have tested some 28 As and Bs and was not impressed. They are kind of the equivalent of the 26F but they state you can charge them more. You gain ~200-400mAh and lower its lifetime/cycles.
Most likely they used slightly altered chemistry like they did on the phone batteries.
Verdict: over-chargeable 26F.
