Samsung INR18650-30Q Cell Specifications
TheBatteries
Brand:Samsung
Model:INR18650-30Q
Capacity:3000mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1500mA Standard
4000mA Maximum
Discharging:2.50V Cutoff
600mA Standard
15000mA Maximum
Description:Purple Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://eu.nkon.nl/sk/k/30q.pdf
https://eu.nkon.nl/sk/k/30q-specs.pdf
Pictures:
Found these cells in Milwaukee cordless tool batteries M18 6AH and 9AH. May also be in the 12AH, but yet to get hold of any.
I saw these on a spec sheet and they say 3000mAh capacity with a discharge current of 15. Im a little confused. Is the amp rating 3Ah in this case or 15A?
Capable of 15A discharge and has 3000mAh capacity . Confusing discharge rating with capacity rating. two different items
@Wayne's World, the 12AH uses larger 21700 cells.
M18 6AH is found in 2 versions: XC uses 18650, High Output uses 21700s.
