Sanyo UR18650W2 Cell Specifications
TheBatteries
Administrator
Brand:Sanyo
Model:UR18650W2
Capacity:1500mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1050mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
300mA Standard
--- mA Maximum
Description:Red Cell Wrapper
Pink Insulator Ring
18650 Form Factor
Data References:
http://www.datasheet.jp/download.php?id=1006973
Pictures:
[ATTACH=full said:
0[/ATTACH]
mike pid='36073' dateline='1535631797']
JapanPowerWall said:
According to a few datasheets I found, the max discharge current is 15A..
Can you please post links to the datasheets you were using?
This isanofficial Sanyo PDF datasheet for the UR18650W2:
  • datasheet (dragged).pdf
Yeah, you are right, thanks for sharing. I just wonder that it is not in cell database and the another cell with Pink insulator is here presented with capacity of 1500mAh, so that could went to misleading information in some cases - for example if someone would have this wear outbattery with just 1500mah capacity left, but he might be thinking that he actually is having a good cell with 100% capacity left...
