Sanyo UR18650ZTA Cell Specifications
TheBatteries
Brand:Sanyo
Model:UR18650ZTA
Capacity:2900mAh Rated
Voltage:3.70V Nominal
Charging:4.35V Maximum
1450mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
580mA Standard
5800mA Maximum
Description:Purple Cell Wrapper
Yellow Insulator Ring
18650 Form Factor
Data References:
https://na.industrial.panasonic.com/sites/default/pidsa/files/ur18650zta.pdf
Pictures:
I'm a newbie at this. I just stared collecting cells for a couple power pack projects. I'm getting loads of old Dell 93wh packs from my IT department, and these are in most of them. Great cells so far.
mike said:
Pyromancy5 said:
The linked cell info is for a Panasonic cell, and is incorrect.
Panasonic owns Sanyo.
Thanks! I should just keep my mouth shut about it then. The drawing looked more like a Panasonic button top too, but it's not drawn to scale either.it looks like Panasonic owned Sanyo until 2015. My cells of this model are older than that.
I have several of the UR18650ZTA with white ring
And SD3A after the model No
Found 4 of this.... but look a bit smaller than a normal 18650
Got one of these (recycled from somewhere). Still has above 2000mAh@1A. Keeping it for some special unknown occasions or tests.
Hello people.
Where is the release date on the cipher of these 18650 classified? The Internet did not help, other batteries are easy to recognize, but these pink cans have a very complex code.
Tell me please
Regards,
Gavr
Sanyos? try the 18650 date lookup at top of the page under battery tools links to Battery Bro
Thanks for the answer friend. But there is a strange cipher. UR18650ZTA V53A. I looked at the links and datasheets, but nowhere are there release dates for this particular model.
Regards,
Gavr
link is broken.
several sources claim 2800mah
IR unknow, sorry
sorry mist the A after ZT
