Search for 24v Battery 200AH / 4800kWh
Marckcity
i am searching for a chep battery
24v and 200AH or 4,8kWh
18650 or lifepo4 or from e cars then i can make my battery
regards
Roland W
Finished battery or cells only?
Salvaged cells 18650 or LFP bricks, every country has a different market availability for this kind of stuff. Sometimes even laws making it hard (you are from Germany, right? Recycling laws :)
New cells, I would definitly recommend to go LFP. The 280Ah bricks seem to be handy these days (ca. 100 Euro/kWh)
Finished systems, you can find chinese manufacturers on Alibaba. LFP 5kW/24V packs. They will build it as you ask for. Probably somewhere around 1000 Euros for such a pack shipped to your door.
Any particular reason why 24V? If you are later planing to expand your system, go for 48V. Lower currents make things much easier.
Marckcity
Lfp is a option, right
I need for 24v because my inverters have this voltage 😁
cells ok too because i can make myself a battery pack
regards
Roland W
LFP short for LiFePo4 or Lithiumferophosphate ;)
If you're willing to build a 24v@200ah 18650 battery... you could do this with 7s67p 3000mah cells. That's 469 cells at 3000mah each (or a few more cells at lesser mah each). It so happens that Battery Clearning House is selling RING packs - and they have 2 x 3000mah cells in each one. So if you bought 3 of these - https://www.batteryclearinghouse.com/products/lot-of-300-panasonic-ncr18650a-cells-in-ring-packs - (3 * $135) you'd have enough cells. I just processed 1600 of these in last 6 months and they were 99.9% 3000mah / great cells for low amp/cell (powerwall) type applications.
3 x $135 = $405 for 600 cells. *This is pretty cheap in the grand scheme of things*
OPUS(testers), wire, solder, holders, etc - $300?
BMS - $200?
Just to give you a baseline - I think you could build a 24v@200ah powerwall battery for <$1000 if you're willing to invest some time.
Marckcity
BMS - $200?
this is really a good idea with the 18650s I actually wanted to do it that way. When I tried to buy cheap cells, I quickly noticed that I can't find anything under 2.20 € per cell at the moment. then i thought for the money i can also order lifepo4 from aliexpress. but this suggestion with the 18650 cells from the ring batteries is really great 🙏 I've seen it on the site too BYD LiFePO4 24v Battery Pack with 3-4 kWh for 295$
what do you think is the better solution ?
greetings from Germany 😊
Greetings back at ya from US. Battery Clearing House (RING cell link) may not be able to ship to Germany...
I agree its all about what/where you can find batteries. Prices/availability change over months - so patience is good if you have time to just sit back and look for a while. The great thing about LifePO4 (box cells) is its fewer physical cells / easier to hookup and of course they have a longer charge/discharge life.
Definitely a good price in my experience :)
Since you are in Germany it would be much more expensive to buy and and ship the cells If you could import the used lithium cells/batteries into the eu. probably cheaper to get from aliexpress.
The BYD LiFePO4 24v Battery Pack with 3-4 kWh for 295$ Have two of the BYD batteries ones is a 2.8 kwh the other is 2.3 kwh. Maybe BCH has a different batch of batteries now. :( All the other batteries and cells I bought from bch have been great.
later floyd.
