Gregory Charles
- Aug 31, 2018
- 11
Guys I know this is some pretty basicquestions but I'd sure appreciate a hand. I'm pitting together two battery packs to go into my electric golf cart. My wet cell deep cycles have reached the end of useful life and I refuse to replace them again.
I've pretty well figured out the battery pack configuration (13s using 18650s) to get my 48 volt system. I've found a 20 amp charger made for this configuration and now I'm down to finding the right BMS for each pack. As this is a golf cart the initial amp draw (smoking tires) is going to be high. Is this a concern when selecting a BMS or do I only need to concern myself with charging amp ratings?
Second, as stated there will be two packs in parallel to provide duration and distance traveled. Can I charge them in parallel with the same charger? Each pack having it's own BMS.
Any and all help / information is most welcome.
