[SELLING-US/MI] PRICE DROP 12v/14.8v 30000mah Powerizer PL-9059156-1C PR-CU-R574 Batteryspace Lipo Batteries
CUDAcores89
I have 28 of these. This is a copy directly from the eBay listing I have for these batteries.
For sale is one Powerizer 12v 14.8v 30000mah PR-CU-R574 Lipo battery. This battery was used for only a few cycles in a prototype environment and is ready for resale.
The grey 3-pin connector is a constant 12v output from a 12v DC-DC buck covnerter. The 2-pin Molex connector is the charge/discharge connector for the battery. The green PCB is the buck converter and the red PCB inside the battery is the BMS.
These batteries can be taken apart, or used as-is. Each battery pack contains twelve 3.7v 10000mah lipo cells and a 14.8v to 12v DC-DC buck converter to limit the output voltage to 12v. This Buck converter has a buzzer that sounds when the battery pack approaches a low voltage. Testing revealed these battery packs to still retain 80-90% of their original capacity.
Battery pack voltage specifications:
Battery
  • High capacity Polymer Li-Ion battery is made of 12 pcs PL-9059156-1C in 4S3P configuration.
  • One Fuel Guage installed free hanging externally
  • Battery is placed on fiberglass board (Customer provided) with heavy duty shrink wrap in special setup
VoltageBattery:- Voltage: 14.8V (working) 16.8V ( peak) 11.0V ( cut-off), 12V (regulator output)
Capacity30Ah (444wh)
Protection
  • 1xPCB (10A) is installed with the battery pack to protect battery from
    • Overcharging beyond 4.25V/cell
    • Over-discharging below 2.75V/cell
    • Over-drain beyond 10A
  • 1x 7 amp polyswitch installed to limit max. discharging current at 7A and to protect wrong polarity
  • 1x 4A DC to DC Regulator
Pre-wired
  • Discharge terminal: 8.0" 18AWG wires
  • Charge Terminal: 6.0" 18AWG (Molex 03-09-1042, Female socket: 02-09-1104), Pin 1 = Positive, Pin 2 = Negative
  • Free hanging Fuel Guage with 12" wires.
Max. Discharging Rate4 Amp limited by regulator
Dimensions (LxWxH)15" x 8.6" x 0.8" (380x220x22mm)
Weight6lbs5.5oz (2878g)
Individual cell specifications:
Battery cellPolymer Li-Ion 9059156 cell
Specification updated on 9/23/2020
VoltageNominal: 3.7V
Charge Cut-off: 4.2V±0.10V -- CC/CV charge
Discharge Cut-off: 2.75V
CapacityNominal: 10000mAh
Minimum: 9500mAh
25°C, 0.2C discharge
Charge CurrentStandard: 1900mA / 0.2C
Maximum: 9500mA / 1.0C
0 to 45°C
Discharge CurrentStandard: 1900mA / 0.2C
Peak: 19000mA / 2C, for < 30 seconds
0.2C: -20 to 60°C
2C: 0 to 45°C
Impedance≤6mΩ25°C, AC 1KHz after 50% charge
Dimension(LxWxH) with
tolerance ±1 mm
160.0mm x 60.5mm x 10.0mm
Weight200 g / 7oz
Storage Temperature≤1 month: -20 to 45°C;
≤6 moths: 0 to 30°C ;
≤ 12 months: 20±5°C;
Best 20±5°C for long time
Images:
Prices:
$20 each if you pickup locally and pay in cash. I am located in Southeastern Michigan.
$30 each + shipping if you would like these batteries shipped to your door.
Firm on price.
Shipping to the lower 48 states only.
Since i'm not allowed to leave contact information and I don't come here often, I will be checking up on my account every 2-3 days. So expect a delay answering your initial PM. Thanks.
pm me back if you still have some of these. I need 4 of them to make ~56volts. I will need them shipped to Oregon.
