I’ve got some of these INR18650MH1 cells extracted from power storage packs with assembly defects and were used little to none.
For tested cells, all cells testing 3000mah with a majority over 3100mah or more and have capacity written on the cell. All cells were extracted from packs at 3.5v+ and were charged to 4.2 volts and discharged to 2.5v at 1 amp, capacity written on the cell and recharged to 4.2 where they sat for 2 weeks and any self discharging below 4.1v were removed. All cells were then discharged again to 2.5v and confirmed capacity and were not recharged for safety and all sit around 3.1-3.4 volts for storage. All cells are dated 2019-2020. See below for the current inventory.
For the untested cells, all were 3.4 volts or more from the packs, and so far all cells are 3000mah+ with a majority over 3100mah. All cells dated 2019 or 2020. See below for current inventory.
I am located in Foster City, California and will not ship because of the amount of safety regulations and cost, so a local pickup only.
my price is 2.50$ per TESTED cell(3000mah+), and 2.00$ per UNTESTED cell(likely 3000mah+ or close), cash only.
in the coming weeks I will test more and have more cells and will update the post accordingly.
current inventory:
-101 tested cells 3000mah +
-124 untested above 3.4v cells likely 3000mah+
if you want to buy some or all cells, you must sign a document that outlines you understand the risks of lithium based batteries and that anything that goes wrong I cannot be liable for and all possible liability falls on the buyer. Both the buyer and seller will each have a copy.
See pictures for closer details, and message me privately if you’re interested or want more details and locations.
current inventory:
