Sorry if this has been done before, but after finally setting up my battery system (It's still ongoing!) I thought it might be helpful to compile a definitive list, with explanations, of the parameters in Battery monitor for the Seplos BMS. I'm sure some of your expertise will help correct my guesses and shortfalls and help people in the future to work their way around this software. The values on this are obviously only applicable to me (please let me know if you see any glaring errors) but in the beginning I found it very confusing to navigate and understand. The translation isn't the best, which is understandable and the parameters don't seem to be in any order and sometimes appear to be repeated. (I've moved the order of some of the rows so they are more logical to me)
Please note this is just a start and I'm using my VERY limited knowledge to try and work out the correct translations of each parameter, so please be gentle the subject matter expert, keyboard warriors among you! Even though this greatly depends on your input!
I must add, for those looking for a BMS, I'm quite happy with the Seplos (10E). Yes It's balancing ability is non-existent and the software can be confusing, but it seems pretty solid. A lot of the negative comments I have heard about them seem to come from people making mistakes or getting frustrated by a safety setting that is maybe badly translated, but is actually doing it's job!
Anyway, fire away!
Anyway, fire away!
