Seplos Pusung 5.12KWH LiFePO4 battery pack overview by UpNorth Mike
Mike takes a look at his new Solar/Battery setup using the Seplos Pusung battery housing
View: https://www.youtube.com/watch?v=lluhOi0mB2w
Specifications:
Basic Parameters
  • Nominal Voltage (V) - 51.2V
  • Nominal Capacity (Ah) - 100Ah
  • Nominal Power (Wh) - 5.12KWh
  • Dimension (mm) - 565*440*170mm
  • Weight (Kg) - 56.2KG
  • Discharge Cut-off Voltage (V) - 41.6V
  • Charge Voltage (V) - 54.5V
  • Max. Charge/Discharge Current (A) - 100A
  • Communication Interface - CAN,RS485
  • Configuration - 16S1P
  • Working Temperature
    - 0~50℃(Charge)
    - 20~50℃(Discharge)
    - 20~55℃(Storage)
  • Cell chemistry - Lithium iron phosphate (LiFePO4)
  • Cycle life - ≥80% capacity state after 4800 cycles at 0.5C, 25℃, 100% DOD
  • IP level - IP 20
  • Certifications - CE, ROHS, MSDS, UN38.3https://www.youtube.com/watch?v=lluhOi0mB2w
Website - https://www.seplos.com/sale-1331185...f-grid-3kw-5kw-battery-power-home-solar-.html
