- Oct 7, 2016
- 2,218
Mike takes a look at his new Solar/Battery setup using the Seplos Pusung battery housing
View: https://www.youtube.com/watch?v=lluhOi0mB2w
Specifications:
Basic Parameters
Website - https://www.seplos.com/sale-1331185...f-grid-3kw-5kw-battery-power-home-solar-.html
Specifications:
Basic Parameters
- Nominal Voltage (V) - 51.2V
- Nominal Capacity (Ah) - 100Ah
- Nominal Power (Wh) - 5.12KWh
- Dimension (mm) - 565*440*170mm
- Weight (Kg) - 56.2KG
- Discharge Cut-off Voltage (V) - 41.6V
- Charge Voltage (V) - 54.5V
- Max. Charge/Discharge Current (A) - 100A
- Communication Interface - CAN,RS485
- Configuration - 16S1P
- Working Temperature
- 0~50℃(Charge)
- 20~50℃(Discharge)
- 20~55℃(Storage) - Cell chemistry - Lithium iron phosphate (LiFePO4)
- Cycle life - ≥80% capacity state after 4800 cycles at 0.5C, 25℃, 100% DOD
- IP level - IP 20
- Certifications - CE, ROHS, MSDS, UN38.3https://www.youtube.com/watch?v=lluhOi0mB2w
