sistema fotovoltaico 48 v
Domingos Fernandes
apresento o sistema fotovoltaico com bateria integrada v lifepo4, algumas delas construídas por mim equipadas com BMS 48v 50 AH
Very nice build Domingos. Must have taken quite some time to get it looking that well done. Can you post some more information about your build? Perhaps make a thread in the DIY Battery Project Builds section
Welcome to SecondLifeStorage. I just ask to please use English as this is a global platform. :)
Domingos Fernandes
bateria lifepo4 50 AH
It looks like you have only 15 cells in series?
For "48V" nominal systems with LiFePo4 cells, usually people use 16s for best voltage range.
Nice setup! Would you care to share the high level setup info?
- How large is the battery bank?
- What amount of power can you produce / are these MPP Units in parallel?
- Do you have PV?, what size?
- What are you goals?
Looks very good Domingo, congrats! Very professional, I like the project you made :love:
I was wondering what that small box does with the green connector. If it carries current more than 10 ampere do check the rating, I had some of those green connectors melt with a lot of smoke and nearly fire! :cautious:
mas eu tenho ligado em paralelo com baterias pylontech us 2000 , por isso tem que ser 15 S
Domingos:
English only please
Solo inglés por favor
I have already asked you several times to use english, and translation services such as translate.google.com is available
Ya le he pedido varias veces que use inglés, y los servicios de traducción como translate.google.com están disponibles.
I think the images speak for them self lol
Domingos Fernandes
Ficou muito bom Domingo, parabéns! Muito profissional, gostei do projeto que você fez:amor:
Eu queria saber o que essa pequena caixa faz com o conector verde. Se ele carrega corrente superior a 10 amperes , verifique a classificação, eu fiz alguns desses conectores verdes derreterem com muita fumaça e quase fogo! :cauteloso:
suporta até 200 amperes mas tem que ser instalada uma peça para medir os amperes, você encontra no ebay, amp 200 amp DC
