Tech4U
- Jul 12, 2018
- 76
So i have 9
Mission 320w solar mono panels without frames.
Specifications:
Rated Power: 320W
Open circuit voltage (VOC): 46.7 V
Max power voltage (VMP): 37.8 V
Short circuit current (ISC): 9.15 A
Max power current: 8.52 A
Maximum system voltage: 1000V
Fuse Rating: 15 A
Weight: 50 lbs
Dimensions: 1970mm x 990mm x 5mm
I am looking at adding these ( i dont know if i can )
Can these be added in series to those?
Specifications:
Rated Power: 320W
Fuse Rating: 15 A
Weight: 50 lbs
