sasquatch
- May 23, 2020
- 5
Hi all,
I'm dipping my toe into the waters of PV generation and trying to spec out my first few panels/system (off-grid), and am a bit stuck on where to go...
I have a garage roof that's south facing and gets mostly full sun coverage during the day, but there's a few large trees at one end that can cause a little bit of shading on the end panel. I should be able to just about fit 5 x 405W panels on the roof - looking at theJA Solar 405W Mono MBB Percium Half-Cell panel.
In an ideal world I'd like to wire these using micro-inverters so I get 240-ish V out the end to do with as I please (into a Victron MultiPlus for storage to start with I think). The reason for Micro-Inverters would be that should I decide to move to putting panels on the main house, which is east-west facing I think it would be easier to split the panels without needing to mess around with multiple inverters/keeping strings apart to avoid shading issues/etc.
For some reason in my mind micro-inverters just seem a simpler/neater approach - no need to run/handle chunky DC cables, each panel is essentially 'stand alone' so shading of one won't affect any other the others - am I missing something (other than the cost being higher, I guess...)?
Does anyone have any experience of using Micro-Inverters? I'm specifically looking at the Hoymiles manufacturer - as they do 1/2/4 port versions and seem to be rated for UK use should I wish to grid-tie in future. They're also cheaper than the Enphase variants but seem to have broadly speaking the same feature set. It looks like i'll also need their 'control stick' for programming but it's not clear how much access you get to the underlying configuraton without being a 'registered installer' - seems to be the case for both Hoymiles and Enphase?
Cheers
Jon
Cheers
Jon
