Hi all - selling the items below, most new never used, some very little use :
Opus BT-C3100 (like new, barely used)
Battery Spot welder Machine 18650 Lithium Battery spot welding / Welding Machine 110V/220V 3KW With Welding Arm Battery Fixture (new, never used)
10 pcs Micro USB 5V 1A 18650 TP4056 Lithium Battery Charger Module Charging Board With Protection Dual Functions 1A Li-ion (new, never used)
10 ZB2L3 Battery Tester LED Digital Display 18650 Lithium Battery Power Supply Test Resistance Lead-acid Capacity Discharge Meter (new, never used)
2 bags full of cell holders
Some BMS :
2 Original 4S 30A 14.8V Li-ion Lithium 18650 Battery BMS Packs PCB Protection Board Balance Integrated Circuits with cable (new, never used)
Deligreen 7S 16A 25A 35A 45A 60A 24V PCM/PCB/BMS for 3.7V lithium battery pack 18650 Lithion LiNCM Li-Polymer Scooter (new, never used)
7S 24V 20A Lithium Li-Ion Lifepo4 18650 Battery Bms Pcb Pcm Protection Board With Balance For E-Bike Electric Scooter (new, never used)
Connectors and Nickel strip :
10/20pcs XT60 XT-60 Male Female Bullet Connectors Plugs For RC Lipo Battery (5/10 pair) (new, never used)
1 Roll 10m 18650 Li-ion Battery Nickel Sheet Plate Nickel Plated Steel Belt Strip Connector spot welding machine Battery welders (new, never used)
150 Euro for entire pack
Pickup in the Netherlands Utrecht area
Some BMS :
