48v battery->CB->contactor<->6000w 48v inverter/solar chargerWhat are you trying to accomplish with a relay?
What load were you switching? That is the exact behavior of a AC solid state relay when it tried to switch DC. They rely on the zero crossing point for the triac to disconnect and there isn't a zero crossing in DC. The image you show is also an AC solid state relay.I use mechanical relays because I've *never* gotten a solid state relay (like these things):
to work more than once. The internals will make contact but then 'stick' and not release!!! I've tried 3 of them - maybe they were all fakes
Good info! The picture above was just a quick grab but the ones I tried were 'supposedly' dc. I read that people use these OK, not against them, but after 2 failed attempts I decided to go mechanical contactors - where I can see the contacts in operation.What load were you switching? That is the exact behavior of a AC solid state relay when it tried to switch DC. They rely on the zero crossing point for the triac to disconnect and there isn't a zero crossing in DC. The image you show is also an AC solid state relay.
