First thing is to decide if you want off-grid (battery required), grid-tie (no battery but power company approval required) or in-between.
I'll assume for this post that you're thinking off-grid. This means you need a battery but you can use grid-assist (automatically) if the battery is too low such as on a cloudy day.
My house refrigerators are ~2.5kwh/day (as I recall). 3 of these would be 7.5kwh/day - let's round to 8kwh / day as you're working target. But as
@Wolf says, you should get a killowatt meter (or some other means) and see what you actually need.
The next question is your location - solar power for Los Angeles is more even thru the year than where I live. For me, I only get 25% in the 4 winter months of what I get in the summer. You can use PVWatts
https://pvwatts.nrel.gov/pvwatts.php to get an idea of solar panel array size you need for your location to get 8kwh/day (e.g. 31days * 8kwh = 248kwh/month). For example, in Los Angeles a 2,500w PV array (using standard settings) .....
will get you in the ballpark of the following kwh/month. The lowest month = December = 247kwh which is 'just enough' for 248kwh target goal.
A 2.5kwh PV array = 2,500w. That would be 10 panels at 250w each as an example.
From here - you can size an MPPT charge controller. At this level, you might want to consider an all-in-one such as an MPP Solar 3048LV -
https://watts247.com/product/pip-3048lv-mk/ (e.g. off-grid unit) which can handle up to 4,000w of solar panel input, 48v battery, and 3000w of output. This has grid assist + UPS built-in.
But OK, sticking with you're 24v inverter (and battery by implication), you'll need a MPPT charge controller that can handle at least 2,500w @ 24v. I think you'll find that this is pretty high end for 24v and is why I suggested 48v system above. But here's an example of a stand-alone MPPT Charge controller that can reach the 2,500w PV input @ 24v and is popular -
https://www.amazon.com/EPEVER-Controller-1250-5000W-Regulator-Lead-Acid/dp/B07KPD1D5B/ref=sr_1_1 Notice in the description is shows the max Solar Panel input per voltage -
- 100 amp Charge Controller Max Input Solar Panel Power: 1250W/12V, 2500W/24V, 3750W/36V, 5000W/48V. Max input Voltage: 150V. Real-time energy recording and statistical.
and the 2500w/24v just barely meets the theoretical target of 2500w PV array.
And then finally you'll need some batteries. You'll need around 4~kwh/night on average. More in winter, less in summer. To get 4kwh/night at 80% DOD you'd need a 5kwh battery. This would be ~200ah @ 24v which would be ~ 7s80p of 2500mah cells (e.g. 560cells). For 48v it would be 14s40p - same number of cells, just arranged as 14s instead of 7s.
All the above is ESTIMATION based on an off-grid system to deliver on the order of 8kwh/day in a favorable sun location. The point of this is to give you how I would think it thru and to give you some scale and perhaps help you think about how your situation differs.
