maxfirst
- Jul 20, 2021
- 7
Your case is 18cm x 15cm x 26cm right? I turned the battery so the 13s is on the 260mm side made two 13s9p modules.@floyd : Thanks you very much for your advise, but i don't understand two things, so i need one BMS for each battery right? and you said that no second level needed, how its possible because i need 13cells in series and like you wrote 18 x 13 = 234mm, the maximum that i had it's 180mm, so i must have second level.
