urgiv
- Jun 2, 2023
- 43
Have you tried doing a firmware update? How often does this happen? When it does drop, is it the same number of days or is it more random.WiFi dongle decide to drop from my home WiFi network and only way how to goes back online is disconnect dongle from inverter USB and connect back
I have the Sun GTIL2 1000 and initially had a couple of the old dongles.Had anyone experience same behaviour of wifi dongle?
That's why I use the software the Klaus Li made... There is also this project: https://github.com/syssi/esphome-soyosource-gtn-virtual-meter? Other Q I have what if one day Chinese server at http://web.soyo-dg.com will stop working how I will be able adjust inverter...
That's the main reason I completely avoided using anything external to my home network. Hence RS485 comm's only. Been active for months on end without any issues (5 inverters - 4 controlled 1 fixed). Read my thread as you are making life hard for yourself.Other Q I have what if one day Chinese server at http://web.soyo-dg.com will stop working
Yep that's why I decided to gather this info locally. For my eyes only!you should have a constant stream of data going to China and comming back (after they store your usage data)
Another thing that could cause it to disconnect like that is a failing capacitor and the power supply (internal to the dongle) is becoming unstable and locking up the IC.
Possible it could be overheating and causing the issue as well, as the IC could overheat and lock up. (this one you could test by applying some heat to the dongle (hair dryer perhaps) and see if it drops faster)
quite silent on the western front for roughly a year so I want to ask if your system has been stable now for the past 12 months ?Hello Again
Yesterday stupid WIFI dongle drop again and inverter OFF-line
Try reconnect but not success Blue LED not works at bottom of ESP8266 dead
thanks to advise of
Open unit re-soldered week spots on ESP8266 PCB and here we working again
