Moderator
- Sep 25, 2018
- 2,009
Several others, one being @OffGridInTheCity and I have had some odd and funky experiences with them. Much like Lucas Electric/Electronics.But why don't you like them? Or should i ask: what could be/"or is" wrong with them?
The cells exhibit some odd behaviour at times and have a tendency to change IR drastically between SOC phases. Out of the 278 US18650GR G4, G5, G6, G7, and G8 versions that I have tested, I have none that have an IR below 55.2mΩ. All of them performed with a SOH of 80% or better with as high of an IR as 113mΩ specifically the G8. If you remember I did a study on Sony green cells:
Green Sony cells just suck
So Ive tested probably 1000 18650 cells so far from laptop packs and noticed a disturbing trend in the green Sony cells. Most test pretty decently on the initial discharge cycle test (between 1900-2200) but on every single capacity test after that they steadily lose 100-200 mAh per test so I...
secondlifestorage.com
It takes a bit of time and more cycles for internal resistance to fall off a cliff.
