Spots of rust?
106E
Hey I notice some batteries have spots of rust they preformed well 3186mah and from 4.2v to 4.16v after 2 weeks.
Right now I am putting this apart but should i use them for small projects or go strait for the recycle bin?
Bubba
If you can clean it off and it's only on the positive tab, I don't see it being a problem. Otherwise if it is on the walls of the Cell, heating and cooling will cause the rust to keep going (galvanic action), eventually leading to a hole. This is the biggest reason to avoid nickel coated steel strips. If the steel starts rusting .....
So surface rust if it is removable, remove it. Just know to keep an eye on that cell.
