barry_rawn
- Jan 12, 2021
- 8
Folks, have to confess that I ordered a 110V version of the 709A, even though I'm living in a country with a 220V 50Hz supply.
I opened the unit to have a look at the transformer, and I saw that the circuit board that probably implements the single phase triac
www.sunkko.net
is labelled 110/220V.
Question is: does anyone know if I have a hope of modifying this PCB (assuming I could get it out) to be happy with 220V? I would be thrilled and willing to put in the work, because the alternative is dropping 200-300USD for a high-rating step down transformer, or stubbornly spending 100 USD to build one, which probably won't be as good.
I have also submitted a question to Sunko itself but I don't know how responsive they are.
sheepishly,
Barry
How the current level and pulse setting work?
Sunkko spot welder is one kind of Resistance Spot Welder, nickel sheet and battery are held together under pressure exerted by two shaped copper alloy electrodes. Typically the nickel sheet is in the 0.05 to 0.35 mm (0.002 to 0.14 in) thickness range. The two copper electrodes forcing a large...
sheepishly,
Barry
