I am moving closer to the final installation and operation of my 14s 160Ah PowerWall.
I have built all my packs and capacity tested them individually, I have (partially) charged and discharged the whole wall and now I am doing some more work before the final install. The wall is currently set up temporarilyin my shed but once I have finished my work I will move it to the garage and connect it to the inverter.
Here is a picture of a part of my testbench. I used a mix of Tp4056s to charge the cells and ZB2L3s to test the cells powered by a 5V 40A LED supply. I also have some Lii-500s to verify the results.
Below is a picture of part of the temporary setup of the wall:
I used the axial glass fuses (1.5A) to fuse my packs. I tested them and they won't blow immediately at 1.5A but will blow pretty much immediately at 2.3A. Not my prettiest pack but functional.
After capacity testing each pack individually I did not charge up each pack individually but instead made a 6s connection (while still monitoring the remaining packs) and charged these 6 packs using an old laptop charger connected to a boost converter.
I have also used a bunch of power resistors to discharge the pack and verify the Batrium's safety settings.
My electrical safety layers beyond the Batrium's monitoring capabilities include the cell fuses, a main 125A circuit breaker andan EV200AAANA relay controlled by the Batrium under the Critical Bat Ok functionality. This works great and gives me both a manual (circuit breaker) and a digital (relay) line of safety. If the breaker pops I will have to manually reset it and should anything happen, e.g. a cable gets cut or disconnects in any way, I don't need to worry because the relay is of the normally open type.
I had to build a simple PMOS switching circuit because the Batrium's output FETs can only handle 3A and the relay has a pickup current of 3.8A - so to avoid anything blowing up I am switching the PMOS with the Batrium which then switches the relay.
I am also making a PCB right now to include a pre-charge circuit and some status LEDs and manual switches and fusesfor the control logic components. Here is the quick and dirty working version:
As I mentioned, the wall will move and thus, I am building an enclosure of stone, steel, and Fermacell plates for it to have a (God forbid) fire safety line of defense.
